okay wiring volt regulators P 400 delivery
Are the terminals on the regulator marked I - A - S - F ?
Are the two yellow wires both attached to the same terminal of the connector? How about the two white wires, are both white wires together in the connector?
If yes, I would think that you could connect the wires from your old connector to your new connector in the same order they were in. That is I - A - S - F , and then just terminate the unused yellow wire and unused white wire with female "bullet" connectors.
Someone else can chime in, because I have worked on Ford car and F-Series electrical systems, but never a P-Series.
F350SuperCab4x4
02-20-2003 12:55 AM
78bigunns
Electrical Systems/Wiring
10-15-2002 08:09 PM
