Firewall Mount Master Cylider on 1951 F1 - Ford Truck Enthusiasts Forums
Old 07-22-2014, 04:48 PM
grandpas 51 f1
grandpas 51 f1 is offline
grandpas 51 f1 is starting off with a positive reputation.
Looking to mount a new master cylinder and booster assembly on the firewall. I see CPP and POL have diagrams on where to mount but they are for a 53-56. What are the dimensions for where to place the mount on a 1951 stock firewall? As always thanks for the help.
Old 07-22-2014, 05:25 PM
drptop70ss's Avatar
drptop70ss
drptop70ss is offline
drptop70ss has much to be proud ofdrptop70ss has much to be proud ofdrptop70ss has much to be proud ofdrptop70ss has much to be proud ofdrptop70ss has much to be proud ofdrptop70ss has much to be proud ofdrptop70ss has much to be proud ofdrptop70ss has much to be proud ofdrptop70ss has much to be proud of
Depends on pedal position, engine compartment room and the size of the booster. I use OEM stuff but I would do it the same way with aftermarket. Put the pedal set where you want it so it is comfortable and clears the steering column. Then using those measurements mark the firewall and see if you have room for the booster (assuming power brakes). If not move around as necessary so that everything fits in the cab and in the engine compartment. Mine ended up here, no idea of the measurements. Be ready to reinforce the firewall, the 51 is pretty flimsy.
Old 07-22-2014, 07:02 PM
AXracer's Avatar
AXracer
AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Here's where the PO put it on Tony's 50. I like that the gas pedal and brake are both to right of steering column. I wouldn't want to have to leapfrog around column every time I went for the brake. OK if auto and you are a left foot braker (I'm not) I guess. Personally when I put hanging pedals in my 56 I dummied the pedal assembly first until I found where they were most comfortable for driving, then let that determine where the MC ended up. I wanted my heel to be able to rest on the floor and be able to use the pedals like in my daily drivers. Exact position is going to depend on pedal assembly.
Old 07-27-2014, 12:39 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
petemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud of
I have to make this decision soon too. I assume that you have to buy new hanging pedals if you want to put the booster/MC assy on the firewall? Or is there a way to use the the stock pedals?
Old 07-27-2014, 02:19 PM
AXracer's Avatar
AXracer
AXracer is offline
I modified a hanging pedal set from a 93 Camaro to widen the gap between the brake and clutch pedal so they would straddle the steering column. The PO had used a aftermarket hanging clutch pedal with the stock under floor brake pedal! It worked (sorta) but looked like he!! and felt awkward, so I moved the brake MC to the firewall with the hydraulic clutch MC.
If you are using an auto trans, you have to decide if you want a thru the floor or a hanging brake pedal. The MC mounts under the floor in the former choice or on the firewall with the latter. If you decide to use a hanging pedal you might look at and measure the pedal assembly on you jeep, the dash to firewall distance may be similar making that assembly a candidate for a donor, but most any from a vehicle with a vertical firewall could likely be easily modified.
Old 07-27-2014, 04:54 PM
drptop70ss's Avatar
drptop70ss
Different boosters will have different spacing and layout of the mounting bolts, so I normally get the pedals from the same vehicle as the booster so that they bolt up together naturally. Lately I have been using 1993-1997 camaro/firebird setups but have also used early S10 and 78-88 GM G body as well (monte carlo and its similar body styles). Just depends on pedal fit. Most 1980s stuff has smaller diameter dual diaphragm boosters so they fit better than the earlier 1960s/70s stuff, but anything can be made to work with enough head scratching. I am sure there are Ford options as well, I am just more familiar with the GM stuff.
Old 07-27-2014, 09:29 PM
AXracer's Avatar
AXracer
AXracer is offline
It is important to brace the pedal mount And MC mount doubler back to the dash to resist the pressure of applying the brakes so the firewall doesn't flex and crack.
Old 07-28-2014, 11:18 AM
drptop70ss's Avatar
drptop70ss
Yep, I make mine from scrap cutoffs. I also tie back to the firewall as well.
The F1 was so flimsy I also bent up and plug welded a support brace for more firewall flex resistance.
Old 07-28-2014, 04:53 PM
rhopper's Avatar
rhopper
rhopper is offline
rhopper has a good reputation on FTE.rhopper has a good reputation on FTE.
I used a pedal assembly from an early 90's cherokee. I ran a brace from the dash to a plate bolted to the firewall. The pedals bolted to the bottom of the brace and the firewall plate. It's very stiff, the firewall doesn't flex. The brake pedal is placed to the right of the column, near the gas. I heel and toe. The clutch had to be heated and bent to the left of the column. I cut off the standard square pedals and replaced them with oe round rubbers. I used a dual 7" booster which just clears the air cleaner.
#1spudman
07-25-2016 04:13 PM
Chilly Willy in Cali
04-30-2016 11:09 PM
PRG3216
06-28-2015 09:22 PM
1951flatheaddave
15
06-09-2014 12:18 PM
amphiduck
11-08-2013 04:01 PM
Quick Reply: Firewall Mount Master Cylider on 1951 F1
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
