blinkers stay on
Old 11-23-2010, 01:34 PM
newBstroker's Avatar
newBstroker
newBstroker is offline
blinkers stay on
when i turn them on the stay on in the cab and the bulbs. where is the flasher element on out trucks.
Old 11-23-2010, 02:05 PM
Hussler's Avatar
Hussler
Hussler is offline
By your left knee.
Remove the cover and you will see it and the in cab fuses.
Old 11-23-2010, 03:58 PM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
Mine do that every now and then. Just pull the flasher out and tap it on the steering wheel a few times and put it back in. They should start flashing again. When you pull the fuse cover off, the flasher is in the lower right hand slot.
Old 07-24-2014, 04:06 PM
Shmoozer2's Avatar
Shmoozer2
Shmoozer2 is offline
Tap blinker module to fix.
You fixed my blinker constant "on" problem. Removed it, tapped it a few times, replaced and works like new. Thank you.
cdmm151
2009 - 2014 F150
07-14-2020 08:25 PM
justcruzin125
17
03-01-2016 06:44 PM
Weeks7524
12-18-2015 11:28 AM
foxbodyford
11-13-2015 03:39 PM
90pioneer
09-02-2015 09:21 AM
Quick Reply: blinkers stay on
