Newb with a 97 F250
Newb with a 97 F250
Hi Guys, have owned and worked on diesels for years but new to Powerstrokes. Have tried my hand a time or two in the past and got frustrated and gave up. Well....I bought a 97 F250 4X4 PSD auto a few weeks ago. The truck has been sitting about 18 months but started easily with new batteries.
During initial inspection I noticed the engine surging and idling very rough. It also has a loud cackle, maybe one bad injector. If I unplug the ICP it will level out and idle well. I installed some gauges on the hipop rail and fuel schrader valve. Hipop was up and down from 1K to 1.5K with ICP plugged in and 1.5K steady unplugged. Fuel pressure is around 45 PSI.
Driveability is hampered by the fact that the shift **** is broken and the OD wires are just hanging there, does anyone know if the shift lever from a 94 F250 w/o tilt will fit a 97 w/tilt?
Ordered an Auto Enginuity scanner today since I need it to diagnose my truck and have a customer that has 2 Powerstrokes that need some attention.
I've been a regular on the older truck forums and the IDI diesel for years, guess you folks have another newbie to break in for this forum.
Surprisingly the oil is as clean as if it was changed just before being parked. Fuel filter is new. Condition of pigtails and gaskets is unknown so far. There was no oil in the ICP, so I hope it is good. Plan to pull the IPR next and clean it. Really waiting for the AE to get here before I buy anything, not one to throw parts at a problem and hope it goes away.
And how many qts. to fill?
I'm a professional diesel mechanic by trade, just mostly have worked on older mechanical equipment. Have owned many mechanical diesels, currently have 2 F250 IDIs, one Dodge/Cummins and the 53 F100 with a Mercedes diesel for power.
Looking forward to learning a little about the Powerstrokes.
I have run Delo in everything for over 25 years with no problems.
And where in the world did you hear that? If you sold motor oil with sand in it, you'd not be in business too long..
