Oil leak... With Picture
Old 07-20-2014, 08:49 PM
cmsslates's Avatar
cmsslates
cmsslates is offline
cmsslates is starting off with a positive reputation.
Went to investigate a very small oil leak and this is what i found. This is a picture from the bottom of motor looking up. The pulley in the picture is the crank pulley on the very bottom. It seems as though the silicon bead failed on the oil pan and is seeping a small amount of oil. Any quick fix? Dropping the pan is a major PIA and i don't want to do that.
Old 07-20-2014, 09:04 PM
F350-6's Avatar
F350-6
F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
You seem to have lots of leaks tonight. You're first step needs to be to clean things up and watch to see where the leak originates from. A few things up front can cause a leak, and you don't want to just try and fix the part where the oil is since the oil may be running down to that location.
Old 07-20-2014, 09:17 PM
cmsslates's Avatar
cmsslates
I looked over the entire front of the engine. there is zero oil in the valley, and no visible leaks from the hpop. It is only a tiny leak where the pan meets the block. I cleaned it off and drove it for about 20 miles tonight and its definitely this spot where the leak is coming from.
Old 07-20-2014, 09:18 PM
cmsslates's Avatar
cmsslates
I finally got some time to look over everything tonight and this is what i found... I'm not happy about it !
Old 07-20-2014, 09:35 PM
cmsslates's Avatar
cmsslates
Any ideas on what the cause is? Oil pan gasket?
Old 07-20-2014, 09:44 PM
Dan V
Dan V is online now
Dan V has a great reputation on FTE.Dan V has a great reputation on FTE.Dan V has a great reputation on FTE.Dan V has a great reputation on FTE.Dan V has a great reputation on FTE.
There is no oil pan gasket.
Old 07-20-2014, 09:48 PM
cmsslates's Avatar
cmsslates
Thanks for the info! Much appreciated.
Old 07-20-2014, 10:24 PM
jasonc76
jasonc76 is offline
jasonc76 is starting off with a positive reputation.
There is a bead of silicon between pan and block
Old 07-21-2014, 10:42 AM
cmsslates's Avatar
cmsslates
Jasonc76, Yes I found that to be exactly where the leak is. Its leaking from the very front of the pan where it meets the block. seems as though the silicon failed. Any quick fix to this or do i need to drop the pan and reseal the entire thing? Thanks
Chris
Old 07-21-2014, 11:00 AM
Pikachu's Avatar
Pikachu
Pikachu is offline
Pikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud of
Unfortunately, it's more like pull the engine, put it on a stand, flip it over, pull the pan, scrape off old sealant, clean everything with solvent, apply the Motorcraft sealant, install the pan, wait 24 hours, flip it upright and reinstall the engine.
jasonc76
jasonc76 is offline
If it is indeed the pan seal leaking the proper way to fix it is pull the motor put it on a stand up side down clean and reseal.
Old 07-21-2014, 11:08 AM
cmsslates's Avatar
cmsslates
Yea That's what i don't want to do. Any temporary fix to this? any ideas?
Old 07-21-2014, 12:29 PM
JOHN2001's Avatar
JOHN2001
JOHN2001 is offline
JOHN2001 has much to be proud ofJOHN2001 has much to be proud ofJOHN2001 has much to be proud ofJOHN2001 has much to be proud ofJOHN2001 has much to be proud ofJOHN2001 has much to be proud ofJOHN2001 has much to be proud ofJOHN2001 has much to be proud of
Yeah silicone over the silicone wait a day and hope for the best.... It will fail but when is the new question. If it's only a tiny leak touching it may make it worse
Old 07-21-2014, 12:33 PM
cmsslates's Avatar
cmsslates
I will try and add some silicon and see what happens. Thanks
Old 07-21-2014, 01:55 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
If you do that, you'll need to clean the pan and front cover extremely well and bridge the old silicone completely with the new silicone. Nothing sticks to cured silicone, not even fresh silicone.
Quick Reply: Oil leak... With Picture
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
