throttle
throttle
Have not went to parts wanted yet,looked at the add for the 50 throttle linkage and his add said came off 50 woody ,it has the 2 bolt bracket to the firewall==mine has 1 hole each side pedestal type,found another in the add,but has been welded on==will keep looking--mine totally missing.I think the linkage to the pedal is part of the bracket and a separate rod goes to the carb.?
Throttle
Kevin, I live in ohio not (OHO) AS I POSTED but im sure you knew that, anyhow I need all of the throttle linkage,from the pedal to the carb if you have it.Sounds like it will fit from what someone else posted,let me know what you have and how much. thanks, John----I live around the Dayton area--cell 937 313-1694
77dream
07-30-2003 08:54 AM
