Where does this wire go????
My son and I changed the spark plugs in my 2004 F-150 Lariat with the
5.4 Triton V8,v3 engine. Thankfully, we got all 8 plugs out without breakage.
We do have a problem. There is an extra wire that we do not know where
it goes. This red wire come out of the coil/plug harness near the fire wall.
The end of the wire had a trumpet appearance and was about the size of
a dime. In the center was a round object about 3 millimeter in size. Over
all this terminal was very clean. The truck seem to be running fine.
Could anyone tell me where this attaches.
Thanks
Thanks
Thanks
Thanks
I would bet it is the 2nd part of the vacuum line that goes from the back of the intake on the passenger side to the fuel pressure valve
Now to find the loacation on the firewall
purge control valve. ( I saw the part in parts catalog)The redline is a vacuum line.
Now to find this purge valve. Could you give me a little more instructions
on it exact location. Then I will have the job done.
Thanks Dave7.3
82_F100_300Six
07-01-2008 06:28 PM
