Modular V10 (6.8l)
help!!! motor turns over but wont fire up
Old 08-19-2014, 07:52 PM
jakesterrocks's Avatar
jakesterrocks
jakesterrocks is offline
ive got a 2000 ex with a v-10.it turns over but wont start.i changed fuel pump and filter sunday.got it to fire up one but now nothing.the fuel rail has fuel in it.whats wrong with it.oh,and it has a new battery to.
Old 08-19-2014, 09:19 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
First thing I would check is fuel pressure at the rail with a gauge..
Old 08-19-2014, 09:23 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Moved to the 6.8L V10 forum.
Stewart
Old 08-19-2014, 09:27 PM
jakesterrocks
I rented a tester and it showed no pressure. Even when I cranked the motor over. I listened by the filler to hear if pump was running. All I heard when ignition was turned on was a pressure sound then nothing. I'm stumped!!
Old 08-19-2014, 09:32 PM
Bigpipes 35
If I remember correctly a 2000 will still have fuel pump relay, If you have no pressure than replace that first if you continue to have no pressure than its either a wiring issue going to the pump or you got a faulty replacement pump..
Old 08-19-2014, 09:35 PM
jakesterrocks
So I should replace the relay?
Old 08-19-2014, 09:53 PM
Bigpipes 35
If you know how to test it you can but a new one is like $10.00 at any auto parts store so I would just replace it..
Old 08-20-2014, 05:33 PM
jakesterrocks
Yep.the relay was bad.lol.thanks bigpipes!
Old 08-20-2014, 07:29 PM
jakesterrocks
OK.so I'm starting to wonder.truck started up after I changed relay, turned it off for a min.tried it again and it took a bit to fire but did start.then left it sit for half hour not running and it started back up just fine.took it to restaurant to eat and came out and it wouldn't fire again. It took 4 tries, long tries mind you, for it to start.anyone got anything I need to try? Appreciate the help greatly.
Old 08-20-2014, 07:39 PM
Don Sawyers's Avatar
Don Sawyers
Don Sawyers is offline
Same problem different vehicle
I had a buick rendezvous. It would quit running so same as you I replaced the fuel pump in the tank. worked like a charm for a day or two then quit again. pulled the pump and exchanged it for another. Again it worked fine for a day or two and quit again, so I took that pump back and upgraded to a Delphi pump. Again it worked fine for a few days and quit. So I broke down and put it in the shop and they replaced the wiring connector on the harness going to the fuel pump and its been running like a new car ever since. Just a suggestion. Good luck!
Old 08-21-2014, 07:22 PM
Wolfboro's Avatar
Wolfboro
Wolfboro is offline
Fuel pressure regulator ?
hongkongrider
Bronco II
11-10-2011 10:05 PM
bolivartech
4 Cylinder Engines
09-08-2010 12:47 PM
Bob_Flynn
1999 to 2016 Super Duty
11-27-2009 07:17 AM
DJdemon6696
27
12-02-2007 04:43 PM
72F250390
16
07-15-2005 05:20 AM
Quick Reply: help!!! motor turns over but wont fire up
