Alternator question
Alternator question
Hi guys, I have a 1996 ford f250 7.5 v8 460 xlt truck and the other day i went to the store and it was running great and when i came back out of the store and started the truck up i could hear what sounds like air being blown out coming from the engine i drove it home with no trouble at all and when i got home i lifted the hood and im not really sure if its an air blowning sound but some kind of sound coming from around the alternator. I am not losing any power, the head lights are bite and my battery is not dying. So could the alternator bearing or pulley be going? I cant find any air leaks. any help would be great.
Thanks
Thanks
Yes, my alternator has blown both bearings (at different times), and they made an awful noise before going. But before that there was a chirping noise coming from the engine, it was the rear bearing so I was unable to find the cause. The alternator never stopped charging the battery until it failed completely, happily it happened while the truck was parked and I was trying to find the cause of the noise, then suddenly the rear bearing cap blew as I was looking.
update
sorry it took so long to reply, but I took the belt off and the tensioner was good and I spon the pulleys and they feel good and no wobble or are not sloppy when they spin. so could it be something inside the alternator? maybe a fan in it? not sure what to do or should i just buy a new alternator?
thanks again
thanks again
Everything moves together.
If you spun the alternator and it was smooth with no noise I doubt it is anything "inside" the alternator.
Unless it only happens when the stator puts a load on the rotor.
You say "air wooshing", you say "chirping"... I don't know.
If it is charging and not throwing belts I would just drive it.
7622RM
1983 - 2012 Ranger & B-Series
03-31-2019 08:51 PM
Jeff351w
06-24-2005 09:44 AM
woj37
03-08-2004 01:24 PM
