96 7.3 need help!!!
Old 07-19-2014, 06:15 PM
63ferd's Avatar
63ferd
63ferd is offline
96 7.3 need help!!!
I was driving my bone stock 7.3 with 196,000. Was running great. Then the check engine light came on. Loss all power. Very rough idle.
I pulled over and shut it off. After 10 mins of letting it sit. I started it. Still rough idle and tried to limp it home. It died on the way home and would not start again. The next day after it was cold it would start. Still a horrible idle and No power at all and white/gray smoke when it's idle . I replaced the cps and the icp. Still no change. What next?
Old 07-19-2014, 06:39 PM
427 fordman's Avatar
427 fordman
427 fordman is offline
Did you pull the code? I'd start by checking the valve cover wiring harnesses. On the outside and under the covers.
Old 07-19-2014, 09:08 PM
fordpride's Avatar
fordpride
fordpride is offline
X2^^^^ sound like burnt UVCH
Tyler Labaume
10-21-2016 02:16 AM
JosephDunivan
1999 to 2016 Super Duty
08-28-2015 11:12 PM
sean9049
09-23-2014 11:47 PM
duggyb
11-03-2013 07:11 PM
Triple_E_Farms
01-30-2010 09:35 AM
Quick Reply: 96 7.3 need help!!!
