HELP!!!
Old Jul 25, 2014 | 08:31 PM
mikeycars's Avatar
mikeycars
Okay, bought the scangauge2 today, set it up and got some readings. FICM voltage is 48 and up, ICP is fluxuating between 375 to 525, SYC is 0, and IPR is 85%! I got troubles!!!!! HELP!!!!!!! lol!
Old Jul 25, 2014 | 10:38 PM
04badford's Avatar
04badford
OK this is how you use the scan gauge for test's, no HVAC, radio , nothing on.
In park KOEO- ( key on engine off) post results
in park LOW- ( Idling, no RPMs) and post results
In park High- ( 2500 rpm steady) post results
you have 4 to choose from so I'm thinking get ICP,ICPV,IPR,FICM mp.( main power) later you can get FICM lp ( logic power) and FICM vp ( vehicle power) Double check the PIDs entered after awhile they all look the same
Old Jul 26, 2014 | 07:15 AM
2006powerstroke90's Avatar
2006powerstroke90
Replace the IPR and send it
Old Jul 26, 2014 | 07:47 AM
78fordman's Avatar
78fordman
No sync is the problem. Be sure all 3 ficm plugs are well seated and chk the wiring harness to the cam and crank sensors for shorts.
Sent from my leash using IB AutoGroup
Old Jul 26, 2014 | 07:48 AM
78fordman's Avatar
78fordman
You do have a hpo leak too but get the sync problem fixed first.
Old Jul 26, 2014 | 08:09 AM
mustang_309's Avatar
mustang_309
<p>
Okay, bought the scangauge2 today, set it up and got some readings. FICM voltage is 48 and up, ICP is fluxuating between 375 to 525, SYC is 0, and IPR is 85%! I got troubles!!!!! HELP!!!!!!! lol! <img src="http://images.ford-trucks.com/forums/images/smilies2/cry.gif" border="0" alt="" title="Cry" smilieid="26" class="inlineimg" />
</p>
<p>What are the ICPV's at KOEO ( key on engine off )? Also are you showing RPM's on the tach while cranking? </p>
Old Jul 26, 2014 | 10:47 AM
mikeycars's Avatar
mikeycars
Yessir, I'm working on the no sync problem now! Replaced ipr already and it's still 85%, so I'm gonna have to do the hpop huh? The way the truck acted when it died out and the way it spins over now has made me think hpop all along. My brothers 04 did this several years ago. I really appreciate yall's help!!!!
Old Jul 26, 2014 | 11:12 AM
BLADE35's Avatar
BLADE35
I don't think you have a TRUE SYNC Problem
Your SGII is New and so its usually a Programing error with SGII so check the Code you enter
At this Point I would make sure you have Oil Flow to the filter housing During cranking verify the screen hasn't went thru the LPOP basically
My guess is Bad HPOP do to year OR maybe the ICP Sensor got Blown Out this is what we need ICPV at KOEO for so we can verify a Good ICP sensor
hang on let me post you a Good Link to troubleshot it
Old Jul 26, 2014 | 11:14 AM
BLADE35's Avatar
BLADE35
Here is the Link
https://www.ford-trucks.com/forums/1...op-storey.html
Theres lots of good info in it theres even a few HPOP Fix in there but it must fail certain ways for the Home fix to work
FICM SYNC= 07E02209CD 0462050906CD 3601 000100010000 FICM Sync (0=No, 1=Yes)
CMP/CKP SYNC= 07E02209CD 0462050906CD 3701 000100010000 Camshaft & Crankshaft in sync (1 = in sync, 0 = not in sync)
Old Jul 26, 2014 | 11:20 AM
BLADE35's Avatar
BLADE35
Brett asked for this I would Like to see it as well
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
would also like to see FPW Looking for any value other then 0 during cranking
FPW Fuel Injector Pulse Width (
TXD: 07E0221410
RXF: 046205140610
RXD: 3010
MTH: 000800010000
NAM: FPW
Old Jul 26, 2014 | 03:12 PM
mikeycars's Avatar
mikeycars
ICP Voltage (Volts)
TXD: 07E02216AD
RXF: 0462451606AD
RXD: 3010
MTH: 004827100000
NAM: ICV
TXD: 07E0221410
RXF: 046205140610
RXD: 3010
MTH: 000800010000
NAM: FPW
Okay, did have one number wrong, have sync now! ICV KOEO is 0.13. FPW stayed at 0 for a second during cranking then jumped to 5656. Still showing 85% IPR, ICP still jumping around from 250 to 525, and FICM still 48 volts. I had already gone through the wiring and still no sync, so I 'm sure glad you suggested to check my gauge!!! I'm done for today, it's 100 degrees under my carport with 80% humidity and a heat index of around 110!!!!! Thanks man!!!
Old Jul 26, 2014 | 03:16 PM
BLADE35's Avatar
BLADE35
You have a BAD ICP Sensor
Unplug it and start the truck should run in default mode
Old Jul 26, 2014 | 03:48 PM
  #28
mikeycars's Avatar
mikeycars
Are you sure, mines an 03 with ICP in back, not easy to get to.
Old Jul 26, 2014 | 06:40 PM
  #29
mustang_309
yepper that .13 volts at KOEO confirms it, if there is oil in the electrical connection you will need to replace the pigtail as well.
Old Jul 26, 2014 | 09:18 PM
  #30
BLADE35's Avatar
BLADE35
I suspect the ICP Sensor gave a False reading (LOW) and IN Return the HPO System Overpressurized Blew the IPR Screen into (Inside) the IPR Valve
Compleate guess my behalf but I can see it possibly happening due to the chain of events that happens
