Fan clutch always on!!
Old 07-27-2014, 08:49 AM
McFarlandkm's Avatar
McFarlandkm
McFarlandkm is offline
My dad has a '13 F250 CCSB 6.7 w/ 10k miles. I drove it the other day for about 30 miles in 90 degree heat and the AC on. The engine fan seemed to stay engaged the entire trip. Motor nose from the front of the truck was quite loud increasing with rpm to a roar at 3 k!. I even secured all climate controls to see if it would turn off, no joy.
My personal '12 F250 cclb 6.7 w/ 20k on it does not act this way. I just pulled six tons 1500 miles with temps reaching 100 and the fan never engaged.
I hover around 20mpg empty, dad only gets 15mpg empty. Could this fan problem cause the mileage difference and how to fix it???
Old 07-27-2014, 09:16 AM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
clutch fan sounds faulty. They had stuck before. Also the reason for the poor fuel economy.
the tech can manually cycle the clutch fan to determine this issue.
You might try to go out to the fan with the motor off and see if you can turn it. I would not force it but is should spin freely.
Old 07-27-2014, 09:39 AM
McFarlandkm
Senix...I'll check that. I looked for a fuse, but it appears to be controlled by the ecm
Old 07-27-2014, 11:04 AM
senix's Avatar
senix
senix is online now
Conrolled by the ECM.
Old 07-27-2014, 12:29 PM
Dakster's Avatar
Dakster
Dakster is offline
Seems like everything is controlled by the ECM these days. I just reset my ECM so that the HVAC would work. It wouldn't allow any air to come out of ANY of the vents, not even defroster ones up by the windshield. A reset of the computers did the trick. An OBDII and Forscan (which is free) was all I needed.
It's a scary time when now your car has to be "rebooted" for it to work correctly.And don't fret - our GM car has had to been "rebooted" as well.
Old 07-27-2014, 12:52 PM
Mud_Man_Dude's Avatar
Mud_Man_Dude
Mud_Man_Dude is offline
My '11 fan clutch went out. It was under warranty and dealer replace it.
Old 07-27-2014, 03:15 PM
McFarlandkm
Went and rotated the fan by hand with the motor cold and at operating temp. Had the same resistance to turn, but did rotate at least. Now to convince my old man a trip to the stealership is in order.
shaun350
07-08-2015 06:47 AM
Ritory
11-22-2010 04:02 PM
74baja
10-07-2009 08:54 PM
bdrummonds
10-14-2007 03:30 PM
tmcalavy
09-18-2001 12:04 AM
Quick Reply: Fan clutch always on!!
