86 5.0 EFI Valve to Piston clearance
Old 07-14-2014, 07:29 PM
BigDoug's Avatar
BigDoug
BigDoug is offline
Just got the cam chain out and it is obvious the crank was turning and the cam was not. My son said this happened at idle or while he was trying to start the engine. From what I have read this is a low compression engine...but. Does anyone have experience with throwing the cam chain and not doing other damage?
Old 07-14-2014, 07:42 PM
JWC 3's Avatar
JWC 3
JWC 3 is online now
I have seen them with no valve damage . I would put a timing set on and see how it goes . Just my 2 cents ....
Old 07-14-2014, 08:08 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,654 Likes on 1,337 Posts
The 5.0 is not a interference engine. No damage can occur in that engine if the valves hang open and the piston keeps moving.
Old 07-14-2014, 09:33 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
I have only seen valve damage in one single 302 engine, in stock form.
So, it is extremely rare, but can happen. The chances of it occurring, is about the same as hitting the jackpot at lotto.......
Old 07-16-2014, 11:35 PM
BigDoug's Avatar
BigDoug
BigDoug is offline
Thanks everyone. The gear set/chain and new water pump arrive tomorrow from Summit so we will see.
Plowboy34
04-25-2017 08:54 AM
RobW
1983 - 2012 Ranger & B-Series
10-23-2009 09:17 PM
mauicruza
01-01-2006 08:34 AM
14 Fords
03-07-2004 12:58 PM
Racerdave
04-08-2003 04:08 PM
Quick Reply: 86 5.0 EFI Valve to Piston clearance
