Hubs not sliding all the way back on
I took my hubs off to replace my parking brake. I had to pound, pull, and pry pretty hard to get them off in the first place. I got new timken seals... they were about 1/8 short of clearing. Then I got the motor craft ones and I could get them to slide on partially, but not seat all the way back on the spindle... I can get my drivers side on farther than the passenger... I've been working on this all day and I don't know what to do... please help!
I ran into something similar. When I removed the rear hub seal, part if it remained behind. See if this is what you are running into: https://www.ford-trucks.com/forums/1...l#post12633697
Make sure the integral wear sleeve is removed.
on
Look again at pics of the spindle in Jeffrey's link, starting at post #8. You will see the flange of the tin sleeve. The next pic shows it with the sleeve removed. You can pry it off with the hook of a crowbar placed behind the flange. You can also split it with a sharp chisel, but must be careful not to damage the spindle surface.
caedo, if you do scar the spindle housing, there is a real fine sand paper that comes in 1000 grit that works real well to remove the burr. I have had to touch up axles and it takes less than 1/2 an hour to polish both sides. It is important to use a lubricant like diesel fuel, atf etc. so that you are wet sanding, rather than dry sanding. You can then wash off the lubricant with WD-40 and the seals will work well. Very fine steel wool may work, but I have not tried that. Larry
Hey guys, there was a wear sleeve on both sides, one side i had to use a chisel to get off and i did gouge the spindle a bit. I sanded and polished and its not leaking yet. So I think i got lucky there. On the other side i got smart and ran a torch flame around it a couple times and it tapped right off. Now its all back together and working great!
FWIW Stemco makes a two piece seal. One piece is a sleeve that taps on over the axle surface that the seal, which is inserted into the hub, rides on. I used these when I owned my own heavy truck and they work great. Have also seen them used in applications where the axle surface had been torn up by grit. A little RTV under the the sleeve and voila, axle surface fixed. They tried to sell me a seal driver but I found a piece of 2x4 worked well and didn't damage anything.
Grit Guard® Hub Seal | STEMCO
Duzitall
26
02-20-2012 12:43 PM
IndySilverAnny
10-10-2005 03:33 PM
