1999 f350 power stroke rough idle
Hello all I'm new here to the forum.
Was driving my 1999 f350 with the 7.3l power stroke yesterday. I came to a stop and the truck began idling rough and emitting white smoke from the exhaust with a complete loss of power. It did not throw any codes.
Background on the truck: 1999 f350, 108000 miles, banks tuner, Garrett turbo, s&b intake, mbrp exhaust, and it's lifted 6 inches.
I checked the fuel filter it is clean. The white smoke smells like raw fuel but the oil does not. Wondering if you guys could help me with some trouble shooting and problem solving to figure out where to go from here. I feel it may be an injector issue but hoping it is not.
Thanks in advance
Thanks in advance
Update, took the injectors to 3 different ships within 75 miles of my location. All wanted 500+ for the flow test. Just adding the new o-rings did not make a difference, still experiencing the same problems. Would it be safe to assume bad injector? Or should I look for something else?
Thanks
Thanks
Installed the injectors after a bit of cranking the truck fired and ran fine. I let it run until the excess smoke had mostly run off. I turned the truck off let it sit for a while. When I went to start it again, Ithe fuel pump began making a weird noise and crank time was longer than normal. The trucks idle would fluctuate a little from normal to a little rough, when rough it seems like there is a knocking noise coming from around injector 5 or 6.
Anybody know why this is?
