Hit a bump, lose accelerator +CEL on
What would cause me to lose accelerator pedal function after hitting a bump? The engine remains on, the CEL comes on and after a few seconds or shifting into neutral and back into drive I regain the accelerator again and the CEL goes out
The truck shows no codes. It is if some connection makes/breaks intermittently when I hit a rough pavement. Also, she sometimes won't shift in reverse. Could it be related?
Is your truck an automatic?
What tool are you using to pull the codes, many parts store readers will not pull codes on the enhanced powertrain or the transmission,
Could be easy to find still, I would want to check the wiring for the O/D button in the steering column.
WoodNThings O/D Wire Chafe repair PDF
I would check the wiring going over the driver side valve cover for possible chaffing also.
These are just some possibilities and known chafe points for similar issues. As you can tell from the schematic, that fuse controls many things, and with the other issue you are having, you might want to investigate the fuse box for possible corrosion or loose fuse clips.
We had the fuse box apart a couple of weeks ago to fix a crushed connector on fuse #11. The rest looked good and was put back together carefully. Not sure yet why the fog light gets juice sometimes.
I spoke to the mechanic and he assures me that the diagnostics point to the pedal, so I will be ordering a new one today.
He also said that the computer needs a firmware update. Updates make me nervous....
on
Received 3,100 Likes
on
AGrayson84
1997-2006 Expedition & Navigator
11-04-2016 01:57 PM
imprezdcrew
01-31-2012 10:14 AM
