T-case in neutral -- truck won't roll!
The most mysterious part of this whole blown-tranny adventure... We can't push the truck! It will move backward when in gear, maybe with a struggle (I can't say, I haven't driven it since the incident) but when both the tranny and the t-case are in neutral, we can't push it! It feels stuck! What could have possibly happened??
We do need to figure this one out quickly; I'm hoping dropping the driveline will let us roll it, otherwise we probably can't get it on the trailer...
Well with the t-case in neutral it shouldn't matter what happened to it. I'm wondering if the rear end didn't die and gear fragments are getting in between the r&p gears going forward but falling out going backwards. I've had this happen in heavy trucks. I guess it could happen in a pickup, too.
Go ahead and pull the drive shaft first and see what happens but it sure sounds like a differential problem. Or a rear brake problem?
No if it was the t-case it would either be locked both ways or freewheeling completely. Or laying on the ground in 2 pieces. Well I guess if something came apart and was letting the shift forks float around it might lock going forward and kick one out going backwards. When you backed it the 1/2 mile was it still in low or back in high?
Driving in low range with the hubs unlocked should make no difference. Driving in low range long distances can make a difference if you go too fast and overheat the t-case. Or if the oil pump failed that would kill it.
