Ignition Switch Problems on F=1
Stock switch's three terminals are marked: Rad "GA"/Coil/AM
I've hooked the battery wire to each of the terminals to try to separate the Acc. and the Ignition coil but I cannot make it work.
One way I can hook it up to get the acc. but when I turn the key to the other side it connects to acc. and coil at the same time.
The center position is dead.
Hope the description good enough but I am stumped.
Hoping for confirmation on my results before I call Dennis C..
Thanks,
TractormanBill
Thanks,
TractormanBill
Just wired an f1. The diagram above can be misleading if you look at the pic and wire the switch as the orientation of the posts on the switch don't match the diagram. Electrically yes but not visually. Battery feed goes to the longest post, coil goes to the one marked coil and gauges to the other terminal. No need to separate the accessories and coil.
Note that Tractorman has a '52. As far as the ignition switch wiring, using the 48-50 diagram doesn't matter. For that matter, the 51-52 diagrams don't even show the ignition switch. But there are differences that matter, like the starter button (also not shown...).
Note also that anything connected to the ignition switch like original is not protected by ANY fuses/circuit breakers. At a minimum I'd add in-line fuses for the radio and heater fan, electric wipers if you have them, and a circuit breaker for the fuel pump.
It does not show the options like turn signals or cigar lighter. But it does show everything else. I used this to rewire my truck. But I added a fuse panel and removed the 30A and 15A circuit breakers. I also added a head light relay to save the switch from that current draw.
OL-11572-A .. Ignition Switch / Obsolete
1951/52 Trucks / 1950/51 Lincoln/Lincoln Cosmopolitan.
2C-11500-A .. Starter Button (Motorcraft SW-287) / Available from Ford
1952/55 Trucks / Used as the windshield washer push button on 1965/67 F100/250's, located above ignition switch.
My truck has the single terminal starter button and solenoid. Did they change for 52? The diagram says it's for 51 and 52.
Doesn't show the heater fan or electric wipers, both optional.
But I used it and some other diagrams to rewire the truck using the correct wire gauge and color codes.
mike01082
16
02-11-2015 02:50 PM
78half-tonhotrod
10-31-2005 06:55 PM
