Driveshaft center support bearing for 1950 F2
Where is a good place to get the center driveshaft bearing AND the support as an assembly?? I see some places show just the bearing but not the rubber and suport that bolts to frame.
Mac's shows one but only goes to 56-64 year.
I looked at Sacramento vintage but did not see one there. I am afraid of changing just the bearing and having the rubbr bad. I am getting vibration in the cab at 50-55 mph and the steering wheel is not moving. Checked cab mounts (all new rubber) and there are tight.
I would call Chuck Mantiglia. If he doesn't have it on hand he has a distributor relationship with Job Lot and sells at their prices. One or the other should have the assembly. Stu
Chucks Trucks LLC., Chuck's Trucks, Chucks Trucks
The bearing is a relatively common, cheap one, it's the rubber and support that are hard to find. These guys show to have it in stock
This is worth a read too, apparently some driveshaft shops have ones that will fit: https://www.ford-trucks.com/forums/1...t-bearing.html
Ross, if you type the number as O1T you'll find that Green Sales has 2.
While 01T is correct, most partsguys pronounce the zero as OH .. so the number will also be inputed into websites as O1T-4808-B
But, O/01T-4808-B is just the metal support, does not include the rubber cushion.
01T-4826-B .. Sleeve (rubber cushion) / Obsolete
1948/52 F2/F6 & F5/F6 COE / 1953/56 F250/600 & C500/600.
WESLEY OBSOLETE PARTS in Liberty KY has ONE = 606-787-6293.
RED TAYLOR FORD in Corning AR has ONE = 870-857-3518.
KLIMESH MOTOR SALES in Calmar IA has ONE = 563-562-3241.
Pic (lower) does not show F2/F250 (parts catalog symbol D), but the parts are listed in the text section for all these trucks.
T = F5/F500 / TL = F4 / TH = F6/F600 / W = F5 COE/C500 / WH = F6 COE/C600
68horses
10-26-2010 10:29 PM
99SevenPoint3
11-22-2007 09:17 AM
kaufhaus
06-21-2004 11:10 PM
