Shell Rotella T?
I usually run 15W40 and use 5W40 synthetic for extreme cold weather (eg Neon in upstate NY winter). There is or used to be a 10W30 conventional Rotella but its hard to find.
Probably should caveat that with the fact that it was two different engines. The first was replaced because of low compression and I found some piston skirts in the oil pan (hard saying how long they were in there). The second engine was replaced because I finally got around to building the engine of my dreams. Both of those engines were driven very hard and the first one had over 200,000 miles on it before being replaced. Neither engine ever had any oil related problems, both showed consistent oil pressure their whole lives and looked spotless inside when removed.
I love Rotella, I figure you can't beat the price vs. quality. I'm sure there are better oils out there (e.g. Amsoil) but they aren't as readily available and cost more. The only engines I don't run Rotella in are my motorcycle and my Buick, but that is only because I can't get it in the weight I desire to run in those two.
ISSUES:
Flat tappet camshafts undergo extreme pressure and loads, thus requiring an engine oil that is fortified with anti-wear additives to provide premium protection. The severity of higher spring pressure in racing engines also creates the need for additional wear protection. To preserve catalytic converter life, phosphorus levels in motor oil have been reduced. Concerns have risen that oils containing lower levels of zinc/phosphorus could provide insufficient protection in high-pressure areas of flat tappets and camshaft lobes found in many older and high performance engines.
The most commonly used anti-wear additive in motor oils is zinc dialkyldithiophosphate(ZDDP). ZDDP contains both zinc and phosphorus components working together to provide anti-wear protection, and is most important during cam “break-in” procedures. Proper break-in lubes should be used during the break-in phase for all new or rebuilt engines with flat tappets. These lubricants provide the extra protection required to reduce wear at the point of contact during break-in and help the flat tappet face properly mate with the cam lobe. Once the break-in phase is completed, AMSOIL motor oils, which are formulated with high levels of zinc and phosphorus, will provide premium protection to flat tappet cams. The American Petroleum Institute (API) and International Lubricants Standards ApprovalCommittee (ILSAC) have mandated the reduction of phosphorus to extend catalytic converter life. However, reducing the level of ZDDP can compromise protection to engine components, most notably in flat tappet camshafts. Current API SN and ILSAC GF-5 specifications for gasoline engines have maximum and minimum phosphorus levels of 800 ppm and600 ppm, respectively, for SAE 0W-20, SAE 5W-20, SAE 0W-30, SAE 5W-30 and SAE10W-30 motor oils. All engines, especially high-performance modified engines, benefit from oils with superior film strength and anti-wear properties. The flat tappet/camshaft lobe interface is the one area in an engine that has extreme contact load. Since this load increases significantly when non-stock, high-pressure valve springs are employed, the use of properly formulated motor oils is extremely important to reduce wear and extend flat tappet/camshaft life.
RECOMMENDATION:
AMSOIL recommends motor oils containing high levels of zinc/phosphorus for superior protection. The tables above list many of the AMSOIL synthetic motor oils that are formulated with high levels of anti-wear additives:
AMSOIL ZRT,ZRF, AMO, ARO, HDD, AME, RD20, RD30, RD50 and AHR all contain high levels of zinc/phosphorus,maximizing flat tappet/camshaft life in stock modified and high-performance applications.
AMSOIL Z-ROD™10W-30 (ZRT) and 20W-50 (ZRF) Synthetic Motor Oils are formulated with high zinc and phosphorus levels to provide protection in gasoline engines with flat tappet camshafts. Z-ROD oils also contain high levels of rust and corrosion inhibitors for maximum protection during long periods of storage.
AMSOIL PremiumProtection 10W-40 (AMO) and 20W-50 (ARO) Synthetic Motor Oils are formulated with high zinc and phosphorus levels to provide protection in both gasoline(SL) and diesel (CI-4 Plus) applications. These oils are an outstanding choice where high zinc-containing protection is required, such as in late model hotrods that require extra camshaft protection.
AMSOIL Series3000 5W-30 Synthetic Heavy Duty Diesel Oil (HDD) is a combination diesel/gasoline oil with a higher starting TBN to handle the significant stresses from high soot loading and acid generation in modern diesel engines.HDD contains the high phosphorus and zinc required for long life engine protection.
AMSOIL 15W-40 Synthetic Heavy Duty Diesel and Marine Motor Oil (AME) is engineered for use ina wide variety of light and heavy-duty applications. AME is formulated with high levels of zinc and phosphorus to ensure protection of flat tappet camshaft lobes in high performance diesel engines.
While I agree, Rotella is a great oil to use, if you are looking for the best protection, AMSOIL is the best choice. If yall are having difficulty finding AMSOIL products, I'm an AMSOIL Independent Dealer and would be happy to drop ship you anything that you need at a much better price than one may think.
Alternate to Shell Rotell T is conventional Valvoline All Fleet plus diesel oil available in most SAE weights with 1270 ppm Zn rather than only 15W40.
Use SAE 15W40 Rotella T in my 73 FE390 & 73 AMC 401 Jeep engine & 1948 Ford tractor engine all with flat tappet lifters, since it is the most economical higher level ZDP concentration motor oil on the market.
Alternate is Valvoline VR1 conventional racing oil, available in all SAE weights with 1400 ppm Zn & 1300 ppm Phosphorus which available off the shelf at most auto parts stores.
Rotella is the best bang for the buck followed by chevron for zinc ppm and shear strength. Chevron actually has more zinc ppm and a better shear/wear vs rotella but rotella is cheaper.
bobistheoilguy forum, you'll learn more about oils than you thought you wanted to know.
edit to add that I run amsoil myself but in "newer" engines. No sense in using it on 100K+ miles engines.
just my opinion
Otherwise if I was breaking in a flat tappet I would use Rotella T and a zinc additive for the break-in period. But you will get 100 different opinions for this...
AMSOIL Break-In Oil (BRK)
Phosphorus Level - 2040 ppm
Zinc Level - 2265 ppm
http://www.amsoil.com/lit/databulletins/g2881.pdf
Good luck, I hope this helps.
