Shell Rotella T?
Old Jul 10, 2014 | 10:04 AM
vtpkrat2's Avatar
vtpkrat2
Thanks 79 f350! Answers popped up as I was typing(pecking) my previous question !
Old Jul 10, 2014 | 10:33 AM
1979_F350's Avatar
1979_F350
No Problem..... If I can help in any way, just give me a shout.
Old Jul 10, 2014 | 03:08 PM
Chris Popanz's Avatar
Chris Popanz
I personally use Joe Gibbs BR30 oil for break in(1000 miles) and switch to Joe Gibbs Hot Rod oil in a 10w30. Both have high zinc content for flat tappet cams. I run this in my '56 F-100 with a dual quad 351W running a pretty rowdy Crower cam and high spring pressures. cant say enough good about this oil IMO. BR30 has a 2800ppm of zinc or zddp.
Old Jul 10, 2014 | 03:37 PM
Blue and White's Avatar
Blue and White
Part of answering that is calculating the resulting zinc value. Regular STP does not have enough zinc to bring a standard car oil up to the 12-1400 range that moderate flat tappet's seem to like. If there is a different STP with higher zinc, may be enough but it needs calculated.
In general, car oil + additive can be a good solution depending on resulting zinc level. Its not my solution because it is inconvenient, a bit expensive and there is some chance the additive formulation may not mix well with the particular car oil formula.
Old Jul 11, 2014 | 11:55 AM
Tonkatoy77's Avatar
Tonkatoy77
Other people have mentioned it before, but ill comment you shouldn't look at just the zinc levels. The zinc doesn't lubricate properly without phosphorus.
I have been running Valvoline VR1 20w50 in my motor with no issues. I can get it for $4.59 a quart at Napa.
Old Jul 11, 2014 | 06:33 PM
usuallybowtie's Avatar
usuallybowtie
Originally Posted by dustyroad
Unless you just rebuilt the engine putting synthetic to your engine is like burning dollars.
I'd always heard and adhere to the notion that you should use standard oil (with proper zinc levels) in a just-built engine for a few thousand miles before switching to synthetic to let it establish necessary wear in the right places and allow the rings to seat properly.
Old Jul 11, 2014 | 08:04 PM
dustyroad's Avatar
dustyroad
You are right of course. I kind of figured the smart ones knew what I meant without splitting hairs about the proper way to do things. Didn't get into the details because the thread wasn't about that.
I mean really if someone is stupid enough to not follow the recommendations of breaking in a new engine I can't help nor can any forum.
JimPat
6.7L Power Stroke Diesel
37
Jun 12, 2014 04:26 PM
eco
Oil & Lubrication
26
Dec 4, 2007 11:22 PM
dquack
Oil & Lubrication
Jul 14, 2006 09:44 AM
lancer
Oil & Lubrication
Nov 2, 2004 11:13 AM
LK
Oil & Lubrication
Feb 15, 2003 10:18 PM
