rough hp estimate
rough hp estimate
hi im ted a new member. i am restoring a 85 f150. sandblasted frame, all new everything underneath. i did up a 351 windsor(86 block, 69heads) i must mention that i was on a tight budget when i did heads . spent to much and could have bought a am set instead. oh well . i am happy with them .
030 over ,stock crank and rods (good rod bolts)
balanced rotating
kb flats (9.8 to 1 comp.)
comp cam 456/456 dur 268
weiland stealth
heads- ported, 3 angle ,all comp componants, manley valves ,
i need a carb. (suggestions)
rebuilt c6 , 3 55 2500 stall converter.
balanced rotating
weiland stealth
The Comp cam in the 300 I'm building now has the same lift and duration.
So yeah, a set of AFR heads would probably give you another 50+hp. But you wouldn't notice much difference below 4,000-5,000 rpm. How often do you flog it past 5,000 rpm?
I'm partial to Edelbrock carbs because they generally run right out-of-the-box, are simple and easy to tune if needed. Unless you're spanking it a 600cfm is plenty.
on
79muscletruck
16
01-06-2019 05:35 PM
nstueve
02-02-2010 08:25 PM
jerg_064
17
08-08-2008 12:13 PM
73FOMO
10-01-2005 05:48 AM
cjcathey2002
08-13-2002 09:02 PM
