2008 F250 Manual Transmission Fluid - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 1999 to 2016 Super Duty
Reload this Page >
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-01-2014, 08:21 PM
Stan59
Stan59 is offline
Stan59 is starting off with a positive reputation.
I'm looking for Manual Transmission fluid for my 2008 F250 Super Duty V10 6speed manual trans 2WD. My owners manual calls for XT-M5-QM. I can't seem to find any for sale online but I can find XT-M5-QS. Will this work? Or, do you know of another fluid that would work? Thanks.
Old 07-01-2014, 10:20 PM
TexasRebel's Avatar
TexasRebel
TexasRebel is offline
TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.
I'm about to begin the search for this, too... I think you can get it from Official Ford Parts Site | Buy Motorcraft & OEM Ford Parts Online | FordParts.com or your local dealer. No stores carry it as 2008 was the only year it was used, and there was enough of a complaint about hard shifting in the cold that they created a TSB to tell dealers to remedy the problem by using automatic transmission fluid.
The same ATF specified for 2007 and 2009 will work (as the transmissions are identical). Personally, I don't mind the double-clutch on frigid mornings as the MTF is a bit more viscous.
Old 07-02-2014, 02:19 PM
Stan59
Stan59 is offline
That's interesting about the ATF switch. I had an occasional difficult shift over the years but nothing too bad, I thought I was just getting weak!
Is there any reason we should not switch to ATF in our 08's?
Old 07-02-2014, 03:20 PM
Stan59
Stan59 is offline
And to make things even more confusing, if we were to switch to ATF, which one? 2007 Owner's Manual specifies MERCON ATF (not SP), and 2009 Owner's Manual specifies MERCON V ATF.
Old 07-02-2014, 06:43 PM
TexasRebel's Avatar
TexasRebel
According to FordParts: Motorcraft® Transmission Fluids
Mercon V can be used where Mercon is specified, so I'd say the V is fine.
On that same page, you can see that the MTF is an SAE 75w-90 full synthetic.
Old 07-03-2014, 09:35 PM
bucci's Avatar
bucci
bucci is offline
bucci is gaining momentum as a positive member of FTE.bucci is gaining momentum as a positive member of FTE.
My '09 6 speed does not use ATF.
Old 07-03-2014, 10:11 PM
Stan59
Stan59 is offline
What does it use?
Old 07-04-2014, 12:24 PM
bucci's Avatar
bucci
bucci is offline
Manual transmission fluid (gear oil).
Old 07-07-2014, 05:54 PM
Stan59
Stan59 is offline
Thanks to all for the input. I'm staying with the Ford Full Synthetic Manual Transmission Fluid for my '08. This document also helped:
http://www.carquestprofessionals.com...0%206.6.13.pdf
This document answers one of my questions by saying that the current XT-M5-QS is correct for my 08 (even though my owner's manual calls for XT-M5-QM). It also says 'Available from Dealer' which I take to mean there is no suitable aftermarket MTF.
bucci:
This document and the owner's manual I found online both say the 09 6sp with Gas engine uses the Mercon V, where the 09 6sp behind the diesel uses the Manual Transmission Fluid.
Old 07-09-2014, 06:33 PM
bucci's Avatar
bucci
bucci is offline
My owner's manual says to use manual transmission fluid. 9/08 build date.
SuperDutyTampa
New Member Introductions
06-15-2017 09:38 PM
kendall66
09-10-2016 10:59 AM
donmi
10-13-2015 11:38 PM
alumcanTandThd
1968-2013 Full Size Vans
09-08-2014 10:25 AM
kidoo
04-14-2014 07:06 PM
Quick Reply: 2008 F250 Manual Transmission Fluid
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
