Carburetor question-460 swap
First of all, love this site there are lots of super helpful people on here. Hopefully someone can help me pin point this problem...
Im fairly new to carbs and this one is driving me nuts. Its a Carter AFB 625cfm
I got it running, set the timing, idle speed and adjusted everything until i got a good reading on a wideband oxygen sensor. I took the truck around the block for the first time last weekend and after going for about 1/2 mile I would push the clutch in and the air/fuel ratio would shoot to 18-19:1 (super lean). As soon as i stepped on the gas it would drop back down to a normal range, but every time i had to come to a stop it would shoot back to lean (I could also smell it in the exhaust).
So what do i need to adjust/fix/inspect to stop this from happening?
I took it out this weekend and it did the same thing. I would like to actually take this thing out for a drive soon.
The Truck:
swapped one of these in:
The Truck:
for the short time that i have driven it, it runs well. no bogging, hesitation or anything.
It still holds idle when its leaned out, and accelerates off the line fine. I just panic when it gets too lean and drive it straight back to the house.
When I was starting the truck in weeks prior (and even today), i can let it idle in the driveway without driving it and the A/F ratio wont change but as soon as i take it around the block it leans out...
I was doing some research and want to see if its maybe the fuel pump? I have a clear filter and can see fuel moving, but maybe the pressure isnt where it needs to be? Its a brand new mechanical pump so i wouldnt think it would be that but you never know....
Likely not the fuel pump, tuning issue and not a big deal, complicated I'm not going to explain all options.
If you're hell bent on dealing with this, then you need to look at timing stability, idle mixture and carb/manifold temps.
You're not going to hurt anything, drive it.
Do an on ramp at high throttle or something, if it leans out then, then you have a fuel supply issue.
Idling in the driveway it's "loaded up" and hot. Small amounts of fuel stick to the inside of the manifold and little airflow keeps the carb hot making more fuel flow. This isn't an unusual phenomenon. Stock many fords had a heated spacer.
A little lean at idle though is just fine and in many ways good, it keeps the plugs clean. As long as it doesn't miss, backfire, stumble, or slow it isn't too lean at idle.
Basically you want as lean as it will run well at idle, as rich as isn't wasteful or fouling at WOT, and a curve in between. A 14.7 stoichiometric is a guide line not a rule.
Whats throwing me off is that I can let it sit in the driveway and idle for 45 mins and it wont lean out, it just hangs around a normal range. It literally only happens after i drive it.
Im ok with it being a little lean, but 18-19:1 i think is a little too lean; the same way that 3-4 points the other way (11-12:1) is too rich and will foul the plugs/cause carbon build-up. the motor only has 19k miles on it so i'd rather not cause any damage to it.
crazy_urn
22
05-27-2014 12:47 PM
tyrantsparky
02-07-2013 08:31 AM
ranger982
07-04-2009 12:49 PM
1986FordF150I300
22
06-15-2009 05:19 PM
sauerf100s
03-09-2002 11:24 AM
