79 f350 front brakes on 4x4
Hey guys. Ive looked for what seemed like forever but couldn't find any info here yet. Here's my problem. I purchased a front D60 for an 79 F350/ did an arb and some new axles . and brakes. go for a road test and within 1 hour I heard a huge grinding noise. well long story short, the LF caliper was falling off. I had a new hardware kit in it too. checked some more and when I re-assembled everything. I tried to move the slider with a hammer and punch. with the locking bolt in place , I could still move the slider all the way to the inside. Until it falls out. I have a new bolt too. everything is new. I dont know what to do. I used to be a mechanic during this era and I never had this problem. My son , also a mechanic, said they have this problem as well with a newer F650. besides drilling a new hole to better hold the slider. is there anything else to try. the previous owner had redrilled the right side to 3/8 and used a reg bolt. so far seems to be good. If you remember correctly the original bolt has a taper under the head. . Im assuming that the cut outs on the sliders are supposed to be for the bolt. but my bolt body doesn't match with it. Oh I haven't tried a reg bolt to see it the head will hold the slider from going for another walk. anyone had something similar. or know of a reasonable fix?
Maybe you have the wrong bolt .... the bolts for my F-150 brake caliper slider "inserts" have a wide shoulder above the threaded portion to match that half moon shaped cut out.
Here is a pic of the F-350 parts.
http://www.rockauto.com/getimage/get...76-0&width=500
385194-S2 .. National Coarse Thread Bolt / 5/16" -18 x 1 1/8" long from shoulder to end.
1973/79 F100/250 2WD/4WD with single piston calipers / 1973/79 F250/350 2WD/4WD with dual piston calipers // 1976/79 Bronco // 1975/79 E100/150 / 1976/79 E250/350.
Shown as 385194-S in parts catalog pic. Notice 2B486 & 2B487: Originally, there were TWO different types for F250/350 4WD.
Everything is new. the cutout on the slider doesnt hold the bolt. The taper under the bolt head doesnt ever contact the slider. once its all bolted together I can still push the slider all the way out . with the bolt in place. Someone local said I need shims for the main bracket holding the calipers cause its worn out. I cant see that. that would have to be a lot of wear to happen like that not som ss shim. Im also told that some people weld a washer to the slider and then run the bolt through it. Im wondering if I can use a round spacer under the bolt head the increase in diam. going around the tapered portion. maybe the increase in dia. will help. Ive never had this ever in 30 some odd years. Oh the flat spring goes under the slider right?
ManfredVonRichtofen
1978 - 1996 Big Bronco
05-03-2016 08:27 AM
NorthwestX360
06-21-2012 12:44 AM
wyoming1979
04-13-2004 04:54 PM
