front tiedown location for a canoe on a 2012
Howdy! I am looking for a better way to tie down my canoe to the front of the truck without messing up the truck. If I tie it to the tow hooks or anything on the bumper, the tiedown probably damage the plastic I mean chrome grill. The method used here (hood hinges) resulted in unwanted antenna contact but otherwise was okay. It seems like sticking anything under the front of the hood would end up with paint rubbed off... Maybe this isn't just a truck problem, but I've always been able to find a decent front tiedown spot on other cars, probably because the canoe sits far enough forward on shorter vehicles. This angle is just hard to work with. Getting a longer boat isn't an option--19 feet is already difficult. I know some people just skip the front and rear tiedowns but I don't want to. What am I missing? Thanks! <img src=https://lh3.googleusercontent.com/-RtGY9PtSaFg/U6yKWIymTLI/AAAAAAAAEp0/K-L7K9WTsP8/s640/New%2520Bitmap%2520Image%2520%252821%2529.jpg> Also, why can't I post paragraph/page breaks in this forum? Sorry about that. I didn't mean for that to happen.
Kudo's to you for making sure...
that wind coming off the hood and windwhield will put a LOT of stress on the front of the conoe when it gets up INSIDE and acts like a parachute
Can't tell you the number of times someone is carrying something that stands straight up in the front and they thought they had it tight !!!
Maybe cross those front tie downs ?
i.e take the passenger side tie down to the driver's side of the canoe and vice versa...
that way the passenger side one may go 'in front' of the antenna ???
or take the antenna off for the trip ?
r u sure the hinges don't pinch the tie downs where they would wear through and release ?????
I wouldn't trust the mirror arms to secure the canoe. Even though the arms are huge they are still plastic and are only held to the door with two small screws.
Why not put some hooks to the bottom of the camper overhanging the cab and secure it to those?
The shape of the gunnel will force the canoe to stretch the strap as it tries to slide rearward in the wind, imo.
One of those big bumpers with the grill protection bar across the top..?
Sent from my Sprint PC36100 using IB AutoGroup
Hmm. Interesting suggestions. Using my old method with the antenna mast in the glove box is my backup plan. I don't want to use the camper for a tie down for a few reasons. One is that it's good to be able to see the line so you know the thing isn't slopping around up there. The other is that the camper is, well, sturdy as far as RVs go, which means kind of fragile. The main purpose for the front and rear tie downs is to catch the boat if the rack fails. If that happens, I'd expect it to rip out at any camper based attachment point. (And since the rack is also attached to the camper, I really really want those backup front and rear tie downs!)
I can get a pic in the monring i fiund somehwere to tie a loop of ratched strap to bear the front edge of the hood before it turns down and can be stuck up between the crack. I found tying to the front tow hooks around the edge of the hood just wouldnt work and it was impossible to get tight.
