Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Ford C8000 Won't Start: Battery Smoking
Old 06-29-2014, 07:05 AM
coalnation's Avatar
coalnation
coalnation is offline
Question Ford C8000 Won't Start: Battery Smoking
Like the title says, out of nowhere my engine decided it did not want to start and when I do try and start it, one of my batteries smokes. Obviously I didn't want to let it try and turn over for a lengthy time because of the smoke. Before this is fired up perfectly.
Does anyone have any clue as to where I should start looking for the problem?
Old 06-29-2014, 01:32 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
Cables, connections and the starter itself.
You may also want to perform a load test on the battery with a battery tester if you can find one.
Cables can corrode inside the insulation, and especially at any junction with a connecter.
Old 06-29-2014, 08:10 PM
Slowpoke Slim's Avatar
Slowpoke Slim
Slowpoke Slim is offline
Sounds like a dead short while cranking to me. Look at starter and solenoid.
Old 06-30-2014, 12:29 AM
80broncoman's Avatar
80broncoman
80broncoman is offline
X2 on that last line for sure.
Very true. They can look fine and have all kinds of corrosion in there on the copper.
Old 06-30-2014, 07:26 AM
coalnation's Avatar
coalnation
Thanks for the input. I'll go check it out soon.
Old 06-30-2014, 04:38 PM
coalnation's Avatar
coalnation
Granted everything is rusty as hell, the connections seem okay. Is anything supposed to go on the empty post in the front? I did have one loose wire near everything.
Old 06-30-2014, 06:37 PM
coalnation's Avatar
coalnation
Well I replaced all the connectors and cleaned the hell out of everything. I guess this story has a happy ending.
<iframe src="//www.youtube.com/embed/NdzLTmXfGcY" allowfullscreen="" frameborder="0" height="360" width="640"></iframe>
Old 06-30-2014, 06:46 PM
80broncoman
With all that rust I'm surprised that the solenoid was still grounded.
For that matter If (when) you have other electrical problems on that vehicle always check your grounds.
Old 06-30-2014, 08:21 PM
coalnation's Avatar
coalnation
Starting "Operation Destroy All Rust" in the morning.
Codyaye
1999 to 2016 Super Duty
02-15-2016 10:03 PM
74scamp
01-04-2010 09:50 PM
wesh
1997 - 2003 F150
11-03-2006 12:13 AM
DirtSquirt
1983 - 2012 Ranger & B-Series
11-07-2005 10:42 PM
LOHRTBT
02-27-2004 11:21 PM
Quick Reply: Ford C8000 Won't Start: Battery Smoking
