Speaker Bracket / Radio Bracket 1967 F100
Unknown. Can't tell by Ford micro-fische. 1967 speaker bracket was only serviced in a radio,speaker,etc install kit. The 1968 and up was sold separate or in a 1968 and up kit. (BRACKET C8TZ18815A). Looking at Ford's drawing of the 2 kits exploded the 67 and 68/ brackets are shaped the same but different reference numbers are pointing at them. You would have to take out your glove box and try the 1970 bracket. Nobody shows the 1967 radio bracket/faceplate. (C7TZ18842A). Suggest you watch EBAY for all the above.
Looking at Ford's (parts catalog) drawing of the 2 kits exploded, the 67 (left) and 68/72 (right) brackets are shaped the same but different reference numbers are pointing at them.
Here are some pictures of a complete 67 radio, face plate, speaker, speaker bracket, 67 correct radio ***** and radio bracket.
Now here are speaker brackets, the black one is for the 67. The dirty grey one came out of a 70 f100 The dirty grey one I compared to one I have from a 69 and they were both identical. Which leads me to believe that the 67 speaker bracket is also different than the 68-72 Will it work? I would say yes, but I would look for a correct one. That's just me.
Any ideas besides finding a donor and welding new ones?
Just fab up your own ears. Why would you need a donor. None of this will be seen once the face plate is on.
