North Dakota F-3 Time Machine Find
Yes to the tilt bed. What you see is a belt-driven pump that has a mechanical clutch, like an old PTO winch. On the firewall is a small tank. I plan to purchase the pickup for the engine, front bumper, and other odds n ends. My car pool buddy wants the cab for his father's F1 he wants to redo. The owner is a just-retired cat-skinner at the mine.
The odometer shows 25,000 miles. It was used to haul coal for his shop's stoker furnace and dirt. He blew the rearend out a couple years ago when he put her in low with a couple tons of coal on board. Only thing on the engine I can see that's been touched is the after-market carburetor, it doesn't have 7RT on the bowl.
Fellow has some at his dad's he might cut the flatheads out of. Couldn't be sure of the years, but thought that one was a '50. When I stop again, I'm going to ask him to save some stuff if it's usable. The spare tire in the bed I found interesting. 'Tis a 17", but looks to have a split ring on it.
The turn signals are rounded in the back. In addition to the west coast mirror on the driver's door, there are two on the floor boards that are similar. It has a dome light in the tool tray that I believe to be original. It also has the Magic Air heater with the elusive embossed fan motor cover, complete with tabs.
I'll have to look for clips. He didn't swap rearends. Just parked it after the rear quit. The rivets on the ring gear let loose, so he removed it. He started using a pickup trailer. Might be tempted to use the frame/box/hoist as a trailer...A starter motor or my old one lung Wisconsin would turn the pump.
