no fuel flow '86 f250 7.5l
Im bringing my 1986 F250 7.5l back to life, and have it down to the motor will turn over, will try to start if you pour fuel in the carb, but no fuel flows. the Fuel guage is dead, and switching the tanks does not work. But before I begin pulling the dash apart, where is a good logical place to begin looking for the disconnect. I have heard a lot on this sight and others about the fuel pump relay (cant find it under the dash), and also the possibility of a bad oil pressure shut off switch( found, but how to test?). So, any ideas where to begin following?
Do you get fuel while cranking the engine over?
This should always be the case since the interlocks are bypassed.
If not, then don't worry about the inertia switch, oil pressure cutoff and fuel pump relay for now.
The pump relay is under the hood on the drivers side.
Check the fuses.
From the sound of it, the switch valve on the drivers side frame rail is not connected or has failed completely.
Even if the switching relay had failed the truck should default to the rear tank.
Check the fuses.
Dean Ledgerwood
08-05-2016 12:02 AM
paulwjax
21
08-24-2015 07:07 PM
Joshlovesjeeps
16
08-07-2013 06:41 PM
matthnatow
07-13-2008 03:06 PM
