transfer case output shaft loose
anyone had to replace the bearing and seal on the rear output of the transfer case ? I have a lot of play and had bought the bearing and seal a few years back but I need to do now I am getting vibrations and there is a lot of play up and down u-joint looks good but shaft moves a lot. I know some of you guys got more miles than I do (325000) , anybody have this problem? I am thinking im gonna tear it apart this weekend. before I put some bigger tires and go wheeling next month.
Turns out mine was just a loose nut. The one that holds the flange to the output shaft of the transfer case, not the one behind the wheel =P
1-1/2" socket and 3' breaker bar tightened things right up!
On second thought, I'm not sure if the F450s have the same drive shaft setup as the smaller trucks...
[QUOTE=materthegreater;14449173]Turns out mine was just a loose nut.
thanks glen that's what it was. mine was the same thing nut had backed off a little she is tight now. I would bet there are more out there you all better grab the the front of the rear shaft and see!!
reps sent glen thanks wes
ps I cant seem to get the smileys any more?
WhoIsJohnDoe
08-18-2012 07:46 PM
CPUNeck
07-11-2011 05:52 AM
Tony G
09-05-2000 10:17 AM
