what is best way to monitor 06, 6.0 ?
I've never done it....doubt I ever would. But if I did....I would want to use screws/locknuts and have some type of backing plate so the load would be distributed over a larger area vs. just the screw holes.
Hmmm, I'm still Bluetooth but am thinking of going hardwire when I get a tablet. My routine is: plug in the adaptor fire up the app, in a second the 2 are connected, turn the truck to On (for glow plugs) it takes another second or two to connect to the ECU, but I wait a good 20-30 seconds to go to start anyway, and I'm usually watching voltages 1st and then while cranking. And it's fun to see my one sync gauge go from red to green . Sure would like to get the second Sync that you SGII folks seem to have... (I say that because you are looking at the same PID, as far as I can tell) -- I could just create a second gauge and call it FICM Sync I guess...
Regarding the RAMMOUNTING products....
Has anyone screwed one into the dashboard above the radio? Does it hold or is it too soft? Or is the window mounted suction preferred?
I think an ipad mini on the dash would be good for the DashBoss product. I'm currently using an iphone for it. BTW, I much prefer the DashBoss product to the Scangauge and I have them both.
center console pocket. I just used some wood screws to mount it.
So I think the dash is thicker and would hold better. I just don't
like making holes in the dash that will show if I remove something.
Sean
67SuperSnake
1999 to 2016 Super Duty
10-14-2011 12:14 PM
