Help!! Best alternator out there?
pass 2 nights when I hit that gogo juice pedal on the right. First thing in the AM going to check for loose connections battery/ alt. ect... But if it is the alternator whats the best aftermarket one out there? Preferably higher amps. Ill be running a couple of extra things on this tug boat lights and other miscellaneous things. Heard napa has bad reviews but idk. Any advice would be great from fellow X's out
I got a high output alternator for my 6.0 from these guys: Ford Alternators - Truck Tough High Output Alternators | Online Store
So far so good on mine, and they may have what you are looking for.
Good luck!
Good luck!
This place has 100% new alternators both stock and higher amp.
http://alternatorparts.com/
Don't know what year you have but if you have an 04'up 6.8l you have to make sure you buy the right size alternator. My 04'' 6.8l take a large case 6G but my dads 03' 6.8l has a small case 6G.
My battery light comes on and voltage drops when under heavier load over 4k rpm. I am rebuilding the alternator myself. Already got the new HD voltage reg, HD rectifier, new bearings, slip ring, tolerance ring and etc.
DC power is the way to go with any Alt. Second option is Mike Singer Welcome to Singer Alternators | Singer Alternators a bit cheaper than DC same quality.
keating8070
09-07-2010 05:43 PM
fordtrucklover94
Electrical Systems/Wiring
08-03-2007 08:18 AM
