66 F100 Build
#46
#47
#48
Got back early Friday and decided to try my hand at cutting and grinding metal to build some motor mounts, thank God for great neighbors, I had everything cut drilled and ground and he tacked up the pieces and then completed the welding.....
Some channel and plate and a lot of patience
Grind the corners, clean off the rust and a coat of paint should do the trick
Hopefully the oil pan I got from eBay will arrive soon, clean that up get it in place and it's time for the headers and exhaust.
#49
#50
Yes, I will have one fabricated, I'm not much of a body guy and fortunately my truck doesn't need too much. I don't think that was much help but I did want to answer your question.
#51
Motor mounts done!!!!
Well the paints dry and they are attached, everything fit so far, I'm keeping my fingers crossed that the next few steps line up as well.
Driver side, I may be lucky enough to use an oil filter without relocating it like before
Passenger side
Oil pan clearance on the crossmember
Passenger side
#52
Headers in
I ordered Hedman Headers and needed to check clearance with all the changes, quite a bit different than the stock exhaust manifolds. Somebody is watching over this project because the headers clear and it looks like the steering shaft won't be obstructed.
Easily fit and the steering shaft should clear
Tight but it fits.
Rear view.
I couldn't imagine putting these on with the cab and fenders in place....
Tight but it fits.
Rear view.
#54
#55
#56
Thanks, that's what is great about these forums, tips like yours are shared and everyone reading benefits, Thanks again.
#57
Here's an article on how to do it....How to Fill in the Factory Fuel Filler Hole - Custom Classic Trucks
#59
#60
