Dreaded current leak - where to start?
I figured I had a load tester for my batteries already, my truck's lights i.e. 200w of high beams, + 200w of driving lights + 110w of fog lights, + HVAC blower on full, + hazard lights on.
Essentially, turned everything on and measured the battery volts. With all of that load on the batteries held 11.6 volts.
After turning everything off I removed the neg lead and hooked up a Amp gauge between the lead on the neg post. There was hardly any drain - had to use the milli-amps scale to find it, and even then the reading was near minimum. So I just cleaned up the post & clamp and refitted the lead.
I checked the battery rack at the local Supercheap. You can get the H/D Century with 3 yr warranty for $175 each.
I've got a Ctek conditioner/charger hooked up to the batteries now, if it doesn't lift the batteries to 100% within a week or 2 I think I will pull the pin and replace the batteries with a couple of the top spec Century H/Ds from Supercheap.
I did figure something out though, and I know I'm not the first.
When I switch on the truck the WTS and glow plugs come on taking the voltage down to 11.6. The WTS goes out, but the glow plugs stay on for maybe a minute. As soon as the glow plugs go off the volts jump to 12.2. If I wait & then start right at the point when the glow plugs go off then I get the easiest start.
84&04
20
08-28-2015 06:24 PM
amc_martin
03-25-2009 08:47 PM
