rear wheel hub
rear wheel hub
07 Edge with 97k started making a loud noise from the rear, turned out to be a wheel bearing. You can not replace the bearing only, have to replace the complete hub. Being a FWD model I guess I had it easy, wasn't even a one beer job. A T60 Torx bit, a couple metric sockets for the brake caliper and bracket and an 8mm for the antilock sensor, and of course a torque wrench. I read a lot of different things saying you have to change the trailing arm as well but I am trying to determine if that was for AWD models or FWD as well. Anyone else have this issue pop up?
burning coal
1999 to 2016 Super Duty
08-02-2010 10:11 PM
pipman76
13
11-07-2008 12:23 PM
bobbybog
08-04-2004 03:39 PM
