Fass pump
Fass pump
So I picked up a fass pump the other day and I found this
FASS filtration deception. - Dodge Diesel - Diesel Truck Resource Forums
Wouldn't ya know I found it right after I bought one and every body only talks about how great they are but it says in the posts the water separator doesn't even separate water untill gravity does it after the truck is off. Have they improved any since then? Should I try to return this thing? It says they have changed filter manufacturers since then but I'm skeptical they are trying to market a product.
Wow, what a read. I have to assume that Airdog must have the same issues since they are built by the same manufacturer. I just bought an Airdog 2 and now have some search to do, something I should have done beforehand. My fault of course. I am a new diesel owner and take a lot of stock in what I read here and naturally was horrified by the stories of injector/hpfp failures related to water issues. My decision to buy the aftermarket Airdog was only for the filtration and reliability it promised, not performance. So now maybe I have less water separation protection than OEM??????
Been doing a little research and you are correct in that the sky is not falling. There are several manufacturers that produce excellent water/fuel separation filters. One of the best is Baldwin which has been tested to remove 99% free water and 96.5% emulsified water on every pass. My personal good news is that Airdog now sells their units equipped with Baldwin filters. But if you have an early Airdog the Baldwin part number BF1275 may be a good choice next time you change your filter.
Here's a link to a spreadsheet showing some filter spec's;
http://i79.photobucket.com/albums/j1...FilterData.jpg
Here's a link to one vendor who has a very good cross reference capability that you can use to find what will fit your FASS unit;
Filter Products
Filter Products
oxt127
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
02-20-2016 10:18 AM
sparkkky
03-25-2011 12:12 AM
