I want to remove my inside engive cover to access the fuel rail..I unclipped the two bottom latches and the top ones on each side..but the cover is still tight..any suggestions..it is a E450 V10
Originally posted by ersim1 I want to remove my inside engive cover to access the fuel rail..I unclipped the two bottom latches and the top ones on each side..but the cover is still tight..any suggestions..it is a E450 V10
If you are talking about the plastic cover over the throttle body, it is held by the hose clamp on the air inlet also.
Originally posted by ersim1 Thanks for the info...I had the latches undone..but it was still hard to come off...I was afraid of breaking something but one big pull done it...
The heat kinda "glues" the weatherstripping to the dash after awhile. I have the same problem at times. But I see that you got it before I could answer.
