Modular V10 (6.8l)
Engine cover
Old Jul 8, 2003 | 11:52 AM
ersim1's Avatar
ersim1
Engine cover
I want to remove my inside engive cover to access the fuel rail..I unclipped the two bottom latches and the top ones on each side..but the cover is still tight..any suggestions..it is a E450 V10
Old Jul 8, 2003 | 09:37 PM
nafzimo's Avatar
nafzimo
Engine cover
If you are talking about the plastic cover over the throttle body, it is held by the hose clamp on the air inlet also.
Matt
Old Jul 8, 2003 | 09:57 PM
ersim1's Avatar
ersim1
Engine cover
Thanks for the info...I had the latches undone..but it was still hard to come off...I was afraid of breaking something but one big pull done it...
Old Jul 14, 2003 | 11:44 AM
ken04's Avatar
ken04
Engine cover
The heat kinda "glues" the weatherstripping to the dash after awhile. I have the same problem at times. But I see that you got it before I could answer.
