got a beautiful new truck! for real this time...
on
man that's clean through and through.a true survivor.
the E40D's were the only option placed behind the 460 and diesels in the hd trucks (for autos.) however im uncertain if that would be standard or optional in the f150/351W setup.
on the drivers side door tag,you'll see the trans code.
E = E40D
grab the axle code there while your at it,to find if she sports LS or an open diff and which gearing she has.
http://www.drivetrain.com/parts_cata...s_it_posi.html
E = E40D
Thanks it's far from new and there are some flaws but I know what you mean
Btw the trans axle code is E19 which looks like a limited slip E40D w/ 355 gears. Highway truck. I'm gonna have to check if it has OD or not. I can't remember. I think it has 1,2,3 and "D"
Has D47 springs and Y "tape". Not sure exactly what that means
on
First of nice truck.
Y tape means the color of the tape pinstripe in between the light brown and dark brown. I am not sure what exact color it is as I have never looked up tape colors because all my trucks don't have it (I don't care for tape pinstripes).
Trav
Trav
Trav
Trav
What's those springs mean?
#28
#29
on
I have the same tires on my 03, and am pretty happy with them. Just got back tonight from mountain biking in the higher country, and they are very stable at speed on the rough forest service roads, and climb well in loose off road stuff.
#30
on
Those springs are the ratings of the spring lbs it can hold and which ones they are. Frankly I never could figure out which spring was which on the older Fseries but maybe somebody else can. I believe yours are the 5560lb rated ones but don't quote me on that as I am not for sure.
Trav
