changeing spark plugs
Old 06-05-2014, 09:37 PM
Jerry Kirk's Avatar
Jerry Kirk
Jerry Kirk is offline
I have a 2007 fx4 with a 5.4 . I am going to change the spark plugs out so I was wondering is there any tricks that I could do. I know if your not careful they will break and then you have to get an extractor. any suggestions?
jerry
Old 06-05-2014, 09:53 PM
JWC 3's Avatar
JWC 3
JWC 3 is online now
I have had mixed results with all procedures on the crap design plugs . My best for the crap design plugs... Warm engine up . Pull coils . Put Seafoam Deepcreep penatrant in each plug hole . Let sit over night . Best of luck ! Broken ones are not hard to remove with the Lisle tool though . So I do not worry too much . Maybe someone else has other thoughts though ....
Old 06-06-2014, 08:25 AM
RangerFL1's Avatar
RangerFL1
RangerFL1 is offline
Hey. I have a 2006, recently I tried to change the plugs by myself it was not that easy. I would advice to get it changed from mechanic Or may be you wanna try JWC 3 procedure (Sounds easy though)
Old 06-06-2014, 10:53 AM
MikeAF93's Avatar
MikeAF93
MikeAF93 is offline
With a cool engine, use a small amount of PB Blaster to soak the plugs (the stuff works where others fail) and then wait half an hour. Work very slowly. Get the Lisle tool first as even if you are careful, you may still break one or two. I broke two of the eight. If you have it and don't need it, great, but if you don't have it and need it, you're up a creek without a paddle.
The back two on the passenger side will be much easier if you remove the computer harness.
Also, shop around; the plugs range from $11.99 to $21.99 each depending on where you buy them.
As for paying someone to do it, Google search and you will see horror stories of what it cost after plugs broke. Don't know if they're accurate but it convinced me to do it myself. My problem was that after reading about the plug issue I waited until after i got the flashing check engine light to do the plugs. Ended up with a blow catalytic converter.
My 100,000 mile plugs actually lasted 100,105 miles when i started getting misfires. So if you're far below that you may have a while.
Old 06-08-2014, 08:31 AM
thousand_mile_stare's Avatar
thousand_mile_stare
thousand_mile_stare is offline
Old 06-10-2014, 11:02 AM
Jerry Kirk's Avatar
Jerry Kirk
Thanks for the reply's and the info. Now I just need to make my self do it.
Old 06-11-2014, 11:21 AM
RangerFL1's Avatar
RangerFL1
Best of luck !
docweld
2004 - 2008 F150
23
03-16-2024 12:20 PM
2SONS
06-25-2013 08:57 PM
twall_SD250
1999 to 2016 Super Duty
06-12-2013 12:00 PM
96DRW
06-15-2012 04:30 PM
DJPRacer58
1997 - 2003 F150
04-11-2008 01:20 PM
Quick Reply: changeing spark plugs
