Removing stuck rear brake drums
Where the pilot of the axle flange sticks out of the drum, wire brush and file to remove all rust and buildup. Then soak area with penetrating oil of your choice. If that does not do it, then apply heat to the face of the drumfrom just outside of the bolt circle to near the pilot (try not to heat the pilot). Apply the heat quickly, and hit the back edges of the drum with a brass or lead hammer. Or you can see if you can use a drum puller, but I have seen them distort the drum of much force is needed.
Got them off today, I had a wild @$$ idea, so I grabbed one of those disposable fireplace lighters, and I went around the center of the drum near the hub. after about 5 min on each, they came right off. Shoes looked like recent replacements, drums loked to have been turned, even new looking wheel cyls.
1) Remove drum.
2) Turn star wheel and observe which direction moves the shoes away from each other.
3) Turn star wheel back the same number of turns in the other direction.
4) Put the drum back on and adjust your shoes.
5) Repeat on the other side.
Before you ask:
6) Adjust the star wheel until the shoes begin to contact the drum, then back off until they just don't.
Before you ask:
1) Remove drum.
Before you ask:
Before you ask:
Ok thanks
I know there is a gauging tool, where you set one end for the inside diameter of the drum, and the other end of the tool you would slide over the shoes
