What size clutch do I have? ('59 223/3-speed)
Old 07-08-2003, 08:11 AM
VespaJay
VespaJay is offline
VespaJay is starting off with a positive reputation.
It's time for a new clutch set on my '59 F100 with a 223 and 3-speed. All the parts houses list two sizes available, 10" and 11". It's my daily driver, so I can't pull the disc & pressure plate to measure before ordering the new stuff - anybody know how I can determine which size I need to order?
Many thanks in advance.
- Jay
Old 07-08-2003, 08:31 AM
DS02F250
DS02F250 is offline
DS02F250 is starting off with a positive reputation.
VespaJay,
I don't have an answer for you on the clutch, but I did send you an E-mail via the FTE forum... if you wouldn't mind checking it out?
Thanks,
Daryl
'59 Styleside
Old 07-08-2003, 05:08 PM
angus
angus is offline
angus is starting off with a positive reputation.
There's an access cover at the bottom of the bellhousing. If you knew the outside diameter of the flywheel you could figure out the clutch size by measuring the distance between the outside diameter of the flywheel and the clutch disc or pressure plate.
I'd guess that the smaller clutch is the most common, but you never know what you'll find inside an old truck.
Old 07-08-2003, 05:58 PM
286merc
286merc is offline
286merc is starting off with a positive reputation.
Hey Jay were you at Worcester over the weekend?
If your truck has the light duty 3 on the tree it is most likely the 10", the floor box often wound up with the 11".
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
