390 Headers Suggestions!!
Old 06-07-2014, 08:50 PM
GaRedneck91's Avatar
GaRedneck91
GaRedneck91 is offline
I have a 75 F100 4x4 I will be installing my freshly built 390 next weekend. I'm looking to put headers on soon and don't know which brand to go with. Any suggestion on which ones fit the best on these 4x4s?
Old 06-08-2014, 04:24 AM
redroad's Avatar
redroad
redroad is offline
Mad Dog headers
F150-350 4WD 1973-79
Part #9228
- 390/428 engine, 2" primaries, 3 1/2" collectors, fenderwell exit. $
515.00
Sanderson headers
Sanderson FF427 Ford FE Header Set for 1953-Up Ford F100 Pickups
Old 06-08-2014, 04:59 AM
skrudumra's Avatar
skrudumra
skrudumra is offline
The rule of thumb is find the ones with the thickest flanges you can. Sanderson headers offer a beefy 3/8" flange and are made with 16ga. steel and have a 3"collector. They're beefy and don't require gaskets. I've heard people recommend use of a mini-starter when using any type of tube header for heat and clearance consideration.
Old 06-08-2014, 09:46 AM
nkf's Avatar
nkf
nkf is offline
Doug Thorley and 1 up on the mini starter
Old 06-08-2014, 06:56 PM
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
I have the Sanderson's and couldn't be happier. I just run a normal starter and have good clearance.
Old 06-08-2014, 07:36 PM
69cj's Avatar
69cj
69cj is offline
FYI, Thorley is now owned by Pertronix.
Old 06-08-2014, 07:44 PM
GaRedneck91
I'm leaning towards the Sandersons, is it a noticeable difference after adding the headers from the stock logs?
Old 06-09-2014, 03:17 PM
yetiman38237's Avatar
yetiman38237
yetiman38237 is offline
It's like trying to run a mile with a gas mask on and then doing same thing with it off.....you can breathe and your engine will thank you.....
Old 06-13-2014, 07:17 PM
skrudumra's Avatar
skrudumra
Pertronix is the brand of distributor and ignition I've chosen to use. I've heard nothing but good stuff about their products on Ford fe engines. Wakes em right up!
Old 07-30-2014, 02:29 PM
tater_51's Avatar
tater_51
tater_51 is offline
1972REDNECK.........are you running those on a 66 Ford 4X4? I'd also like to run a nice fitting set of headers on my 75 F-100 4x4. I tried a set of early FE hipo exhaust manifolds (really liked the look) but I had frame clearance issues on the passenger side. I believe they would have fit a 66, but not sure. Looking for a set that will clear all stock items (starter, etc) without any modifications. Thanks!
Old 07-30-2014, 03:37 PM
tater_51's Avatar
tater_51
tater_51 is offline
Let me know how they fit!
Old 07-30-2014, 09:23 PM
GaRedneck91
They fit great they ain't blocking the starter, only thing I had to move was the brake lines bracket. I would for sure recommend them. I got em running into 2 1/4 pipe into cherrybombs with turndowns before the axles, sounds great and not to loud at all.
Old 07-31-2014, 07:32 AM
tater_51's Avatar
tater_51
tater_51 is offline
I have a 75 F100 4x4 as well. Looking at the passenger side it just looks like there's not enough room between the stock starter and the motor mount for the header to fit. Also, is there any clearance problem with the the dip stick tube on the driver's side? Thanks
Old 07-31-2014, 07:50 AM
GaRedneck91
They fit around the stock starter no problem and no the dipstick went back in and isn't hitting
Old 07-31-2014, 07:51 AM
GaRedneck91
I have video on YouTube of em look under my channel it's Derek Casey
Weldamatic
01-04-2008 02:44 PM
jmono
08-26-2006 01:47 PM
Quick Reply: 390 Headers Suggestions!!
