vin on frame?
Old Jun 5, 2014 | 10:52 PM
highoctane74's Avatar
highoctane74
vin on frame?
I have a chassis from what I believe is an 1985 F-350 under my truck. Is the a VIN stamped on the frame somewhere?
Old Jun 5, 2014 | 10:55 PM
Fordzilla80's Avatar
Fordzilla80
On my 1980, the vin is stamped on top of the passenger side frame rail, right below the heater box. It's only a partial though, not sure what the 85 will show.
Old Jun 5, 2014 | 11:05 PM
highoctane74
OK thanks. It has lots of paint over it so I needed somewhere to start looking.
Old Jun 6, 2014 | 05:18 AM
Ford F834's Avatar
Ford F834
Most trucks have it there, but occasionally it is "hidden" on the passenger frame rail under the cab approximately under the butt of the passenger. You need a small dentist's type mirror to see it. I have seen a few trucks that had it in both locations, but by far a single stamp on the passenger frame rail below the heater box is the most common.
Old Jun 6, 2014 | 12:50 PM
82F100SWB's Avatar
82F100SWB
Like stated above, the VIN on the frame is only a partial. My memory is a bit hazy as I haven't done any of that stuff in a while so I dug up one of my old posts.
All that's on the frame rail is the model designation, model year, plant and sequence number.
For example, my 81 F100(which is now the 86 diesel in my sig...)
The complete 17 character VIN is 2FTCF10E9BCA40098
What's on the frame is F10BCA40098.
So, not only is the VIN on the frame only a partial, it's also broken up.. The Manufacturer Identifier(first three #'s,) brake system/GVWR class(4th number,) engine code(8th character) and check digit(9th position) are missing
TRUBLU77
15
Sep 11, 2015 07:08 AM
Truck Guy99
Dec 28, 2014 05:27 PM
kip.allen
22
Jan 1, 2013 10:14 PM
BBF-350
Feb 28, 2007 03:36 AM
Randyb12
Jan 23, 2006 11:26 PM
