Coolant Advise & Dealer Suggestions
Been pulling 5th wheel across county from Illinois to the state of Washington. My 2012 F350 showed a message "check coolant additive" a day after going through some pretty steep mountain grades on a day that was 104 degrees. I checked that morning and the little plastic reserve tank was down so I added about 1/2 of a gallon, reset, and all was good. Have gone another 500 miles or so and it was down slightly again, no light yet though. Can't detect any leaking nor can I smell antifreeze. Anyhow I want to have this checked plus have an oil change done around Bothell Washington. We will be at a CG there and I noticed that Ford Of Kirkland appeared close. First of all, does my antifreeze problems sound like radiator going south? Secondly, has anyone had their 6.7 serviced at this dealership?
Your truck takes a specific coolant that almost no parts store sells. I get mine from the local dealer, it is full strength and needs to be cut 50/50 with deionized water(I use distilled water from walmart).
As to it losing coolant, many of us have bad radiators in our trucks, they leak at the seem on the rear left side. The coolant then runs down the outside of the frame just behind the bumper, right below the drain valve on the radiator.
Resendiz
41
10-21-2016 12:46 AM
