leaking steering stabilizer
May 31, 2014 | 08:49 PM
the steering stabilizer on my truck leaves a puddle on the ground every day, even after i put stop leak in. help please. thanks
May 31, 2014 | 09:20 PM
How long does it take you to think up these things to start threads about?
May 31, 2014 | 09:23 PM
Easy... replace it. Done.
Waitaminute.... "Stop leak" ????
I'm thinkin' that's NOT a steering stabilizer. Rather, it's a power steering ram. Post a pic there sparky... let's be clear on what ya got.
May 31, 2014 | 10:33 PM
Moderator & parts slinger
A steering stabilizer is like a sealed shock absorber...you can not service it. It if is for sure leaking, its blown a seal, x2 on just replace it.
Look close, I bet the leak is your p/s pump or steering box...tighten ck the p/s lines. If its the input or output seal on the steering box, you can change the seal with the box installed on the truck.
If the truck is 4x4 and (depending on the year it could have either a Garrison or Bendix Power Assist P/S), and if that where its leaking, that's a whole other story
May 31, 2014 | 11:07 PM
Quote:
Originally Posted by
77&79F250
If the truck is 4x4 and has the old style Bendix
steering ram, and that where it's leaking, that's a whole other story.
If the OP's
1974 F250 has 4WD, it could have either Garrison or Bendix Power Assist P/S.
1973, 1974 F250 4WD
before serial number T80,001: Garrison Power Assist P/S.
1974 F250 4WD
from serial number T80,001, 1975/76 and 1977 F250 4WD
before serial number Y20,001: Bendix Power Assist P/S.
From serial number Y20,001 (that occurred mid model year [February 1977]), there are no more High Boys.
May 31, 2014 | 11:08 PM
I tried to cover both bases.....reply edited.
May 31, 2014 | 11:16 PM
When the hell are people going to stop using snake oil, like stop leak?
May 31, 2014 | 11:23 PM
co425
Never, unfortunately. If it works at all, it plugs up the whole dang system.
Jun 1, 2014 | 02:14 AM
ok thanks for the advice, im not making anything up, just tryin to fix my truck.
Jun 1, 2014 | 02:21 AM
Which power assist ram do you have? Some parts are available depending on if you have the bendix or garrison one.
Jun 1, 2014 | 04:10 PM
Jun 1, 2014 | 04:53 PM
NumberDummy
Not according to
THIS THREAD . Serial number Y25209 was still a highboy made in March of '77.
Jun 3, 2014 | 12:20 AM
so what kind is it? new power steering ram?
Jun 3, 2014 | 04:50 AM
1972RedNeck
Not according to
Whatever you say kiddo, personally I could care less. I'm just relaying what the Ford parts catalog states.
thunderbird1986
2004 - 2008 F150
Jan 30, 2019 07:24 PM
WoomaHodal
Jul 17, 2009 05:35 PM
Marty's 97 F-150
1997 - 2003 F150
May 25, 2009 07:59 PM
