03 CV ifs into a 51 f1???
First off, welcome to the forum.
I believe the CV front end is too wide for this year truck. You may want to research the site for a Jag conversion. They are fairly popular and inexpensive. Several members are working on them in build threads.
Ryans88gt is working on a CV install. He had the parts narrowed to fit. Here is a pic he posted in another thread (toward the bottom) :
https://www.ford-trucks.com/forums/1...ol-gnarly.html
He also has his own build thread here.
Well, there are no parts that were engineered to fit these trucks other than the parts they came with.
The CV front end I would say has a lot going for it with just a little modification.
For all the negativity I got for doing something different, the end result is fantastic and required very little modification.
You get modern coil over struts and A-arms built for severe duty (taxi, cop cars) in a 4000 lb car and nothing really breaks on them. The brakes are dual piston heavy duty discs with modern sealed bearings and the right hub and wheel pattern for late model mustang wheels. And you get built in pads for motor mounts and a modern rack and pinion power steering rack with a hose fitting that bolts right into a mustang power steering pump. And then there are a lot of them in great shape available in junk yards. Kinda hard to beat if you are willing to do a little work to make it fit. If I had to do it over again, I would still chose the CV because it worked out really well.
I'm excited to see someone put a coyote in one of these trucks. Should be awesome!
And did you say coyote? I have one and a 04 cobra IRS just sitting in the shop waiting to go in my 51 with a t56 6 speed as well.
Hey 51,
Hmmm... I like the list of benefits as outlined by Ryan and Crown Vic's are plentiful & easy to find. Are you at all nervous about putting all that weight & stress on a front suspension that's been cut in half & welded back together? It just looks like it would crack open if you put some real stress on it. I'm not an engineer but wouldn't mind hearing from some on this one..
Ben in Austin
1950 F1
Ben in Austin
1950 F1
Hey 51,
Ben in Austin
1950 F1
Ben in Austin
1950 F1
