Towing a fifth wheel with 96 F350 460
Old 05-29-2014, 07:38 PM
duallycrew's Avatar
duallycrew
duallycrew is offline
Looking at fifth wheel campers and am interested in real world experiences of what the truck can realistically handle (trailer weight and pin weight). Truck currently hauls a 7000lb bumper pull with no problems but I understand a fifth wheel is a different animal.
The truck is a 96 F350 dually crew 4x4 with a 460 and a built E4OD. It is one of the aftermarket conversions that started life as a SRW and was converted to a dually.
Don't have the owners manual with me but by memory I think it says 10K trailer limit.
Not looking to travel across country or full time but will likely travel 200 -300 miles at a time.
Appreciate your perspective and the benefit of your experience.
Old 05-29-2014, 07:42 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Bumper pull or 5th wheel makes not difference in how the tuck can tow it.
The truck CARRIES the weight better and turning is different, that is it.
A 7k bumper pull tows just as hard as a 7k 5th wheel.
My biggest confer is how they made the rear a dually? Spacers(bad idea) or dual wheel axle(good idea)
Old 05-29-2014, 07:51 PM
duallycrew's Avatar
duallycrew
The conversion was done with a dually rear axle. It was done by one of the aftermarket companies (centurion or something similar) and sold new at the dealer that way.
Old 05-29-2014, 08:09 PM
Diesel_Brad
That is a FIRST. Centurion is KNOWN for putting bolt on adapters and then Butcher the bed sides putting on generic fenders
Old 05-30-2014, 04:07 AM
350 hauler's Avatar
350 hauler
350 hauler is offline
I'm trying the same
I have a 1994 f350 dually 2wd 4dr 9ft flatbed. Dual gas tank. I'm trying to go into hauling / towing business. Would my truck be good for it. Also if I wanted to pull / tow more than max weight would I just need to add more leaf springs.
Old 05-30-2014, 06:23 AM
Bob Gervais's Avatar
Bob Gervais
Bob Gervais is offline
Without knowing the condition and drivetrain of the truck, it's hard to give a correct answer to that question.
Some general things to note though:
To haul/tow as a business, you want to make sure you go about it legally. DOT and MC numbers, proper insurance, and setting up an LLC or Corporation are all good ideas, and necessary in most cases. Otherwise, you're setting yourself up for fines or to be held personally liable for any damage to customers' items.
There's a LOT of people that haul, tow, and transport illegally. People that choose to do that are taking a HUGE chance on fines, equipment confiscation, lawsuits, and a whole lot of other things that'll result in bad times.
Old 05-30-2014, 08:59 AM
350 hauler's Avatar
350 hauler
Thank you that will all be taken into consideration.
sgeorge
Fifth Wheel & Gooseneck RV Towing
17
10-03-2017 12:38 PM
rbonica
Toy Hauler Towing; Fifth Wheel & Bumper Pull
08-06-2017 05:42 PM
ottomandan
16
05-02-2013 09:12 PM
ArrizX
1999 to 2016 Super Duty
22
02-06-2013 05:44 AM
Cowboy_351
04-17-2002 07:01 PM
Quick Reply: Towing a fifth wheel with 96 F350 460
