alt or battery
Old Jul 7, 2003 | 04:28 PM
fordzrule's Avatar
fordzrule
alt or battery
i have an 88 f150 4x4 with a 302 when i turn my a/c on my voltage drops on my gauge from 14 to about 10 and the belt starts squealing. really gets annoying
Old Jul 7, 2003 | 06:44 PM
mantta's Avatar
mantta
alt or battery
Low voltage to the clutch on your compressor is probably causing the clutch to slip. If you are dropping that much voltage it sounds like your alternator has a couple of open diodes in it.
Old Jul 7, 2003 | 08:14 PM
alabamabuddog's Avatar
alabamabuddog
alt or battery
If the clutch is going bad it will drag and then the belt WILL squeal and becouse the alt is also on the same belt the volts also will drop .
Old Jul 7, 2003 | 10:42 PM
steve83's Avatar
steve83
alt or battery
10V is plenty to hold the clutch fully engaged. The squeal is probably coming off the alternator pulley because there's too much load on it from a bad electromagnet. See how much current the clutch is pulling. If you don't have a good hi-current ammeter, a parts store can clip one onto one of the clutch wires (don't let them clip it around BOTH) and tell you.
